Fiberglass Saddlebags
RE: Fiberglass Saddlebags
Buying a used set is cheaper. If you can find a set on ebay, in the color of your bike, you will be set. Also, the newer bags are made of ABS, much better than the fiberglass, IMO. Also, look at the police bags. I like them, and you can usually find them on ebay for less than $300. If money is no object, I would buy a set of gator boxes, or some other big bag, which is wider, and some are even deeper... just sayin'...
There are alot of aftermarket bags on the market - But in the long run your going to pay more $$$ buy the time you get them color matched and such....
But HD's aren't cheap... around $1400.00 - $1550.00 for the pr... Then you'll need to add matching locks (add $25.00 X2)
Might try calling some Trike Manfu. Companies as they normally\may have a few hanging around... If your lucky you should be able to pick a pr up from these folks for around $1000.00
E-Bay... Just remember you'll never find one that matches the stripe on the tank - But that's a easy fix at the next rally you go to... And if you look and find something on E-Bay mke sure they match you base color and have all the hardware (Replacing hardware is a killer on the pocket book) These normally for out for around $500.00 - $700.00 per set
I have a set that I tried to match the anniversary "sterling Silver" but didn't match exactly....I think they are closer to the H-D Brilliant Silver. I have tried to sell them on craigs list a couple times. problem is I bought them for 500 and then cost me 400+ to paint, but tryin to get like 700 for them. they are brand new looking.........nor cal
