Anyone using Arnott Air Ride yet?
I have about 12,000 miles on a set of the Bilsteins with the compressor on my '08 FLHX. Haven't had a single problem. The install was a breeze! I was especially impressed with how well the compressor fit behind the sidecover. I don't have any clearance issues even with zero pressure. I just did the basic horn mount switch that came with the kit. One of these days I'm going to install a pressure gauge and the handlebar mount buttons. It's really nice to be able to adjust pressure on the fly. Makes it really easy to go from fully loaded two up to just two up or just fully loaded to solo, and vice versa. The most practical reason for it is backing the bike. Dump the pressure and I can stand up straight to push back. It's like having a reverse gear!
Arnott shocks
I have had the shocks on for thousands of miles so far and I am sure I will always have these shocks for now on on all my future bikes, I am very happy with them. I would prefer a compressor that can inflate the shocks faster or maybe look into an onboard air tank. It takes a about 15 seconds to inflate shocks all the way (60- 80lbs from a complete slam). I know it's not a long time but I would prefer instant inflatation.
I have the 13" Aldan's in black. So far so good but not many miles yet. Aldan's have dampening adjustments but they tell you to put some miles on before you adjust. I need to get a air gauge to help dial in consistent ride height.
Here is the bike all the way down(9.5"..no rubbing)
I installed a set of the QA1's on my flht. I added the handlebar controls and mounted my air gauge on the left side of the fairing. I find that I get a good ride at 50-60 psi and I can drop it down to about 20 psi and flatfoot it for backing up. The ride is harsh at 0 psi but I don't get any fender rub at all. I still haven't played with the damper settings so I don't know how much effect they have.
I had the Arnott system for awhile...once I got past the "cool" stage of being able to slam the bike, reality hit me...suspension was too stiff. After trying several different shock combinations, I'm back the the stock shocks. Although they have some shortcomings, they give me the best comfort....
