Tires 880 or Commander
RE: Tires 880 or Commander
FastUltra, what did you dislike about the Metzes? I have them on my FLHT and they were MUCH better than the Dunlops. Got about 10 or 11,000 miles on them, rear looks to have a couple more left in it. They are sensitive to air pressure and like it higher than Dunlops. What did you run for pressures?
Ripp: I went from OEM Dunlops on the '05 Road King Classic to M 880s. I really like them. As said, they are a little more sensitive to air pressure. Riding solo; 36 psi front and 38 psi rear. Riding two up; 38 psi front and 40 rear. I think that they hold their track while on grooved concrete better than I experienced with the OEM Dunlops. I have no experience with Avons, so can't compare there. ..... BC
FWIW, Metzeler recommends a minimum psi of 38 front, 44 rear, and advises to adjust up for load! I've been running 40F-44R solo, and around 42F-46R 2 up with a load.
I bet a lot of people aren't seeing the kind of mileage they should out of these tires due to under inflation.
