SE II baffle removal
RE: SE II baffle removal
There should be 2 or 3 bolts. I forgot which number I think2 though. Youtake them off and if I remember correctly the nut is on the inside of the muffler. Then you take a set of needle nose plyers and pull the baffles out. I suggest to replace them with Big City Monster Baffles though. Keeps the compression so you dont loose power and gives you the straight pipe sound. You can also get it inspected legally with them in the pipes.
Hope this helps.
Hope this helps.
I would call them instead of ordering off the internet. Best way to make sure you get the right product.
http://www.bigcitythunder.com/pages/..._dynamics.html
I think I read you have a 2008. Ok if you have SE II pipes and they fit your bike you can use the Monster baffles but you have to get a lot more done. A Race tuner the works at the dealership to make it work right. If you have already done that then you will have to have it re dynoed to make it work right. More complicated after 2006 models.
