2002 fuel injected road king starting problems
i started the bike last month and it ran fine..yesterday i tried starting it and the battery was almost dead..so i hooked the batter charger up and let it get a good charge on the battery..when i try to start it, it will fire up for a split second then quit, after 3 tries of this the key light will start flashing on the dash and then i have to unlock the security...it will fire right up for a quick second then stop....3 more times then a repeat as above..wondering if maybe the security system thinks the bike is being stolen and preventing it from running???i did disconnect the battery for about 2 minutes also...
RE: 2002 fuel injected road king starting problems
Your bike is acting just like the security system is engaged. You need to charge the bike up completely and then turn off the security system. If that does not work...unplug the security module after you get it turned off and see how it does.
[IMG]local://upfiles/494/3BEA997CB6614A85BBAF8329529CE0C4.jpg[/IMG]
I only have the wallet card to enter bike into service/transport mode:
-Set run/off switch to OFF
-Turn IGN key to ON
-Press and hold the key fob button until confirmation is received
-Turn IGN to OFF
-Press and hold key fob button until confirmation is received
You can probably search the forum elsewhere for other alarm setting mods.
-Turn IGN key to ON
-Turn IGN to OFF
Kong
01-14-2007 08:29 AM
