Battery Tender Use
Battery Tender Use
I keep a battery tender on daily. My current battery is about 30 months old. I have many electrical accessories installed and am really taxing my system. I noticed that after a few hours as usual the green light came on indicating full charge and going to float mode. Without any load a couple of days later the red light reappeared indicating a low or charge state. It has not turned green again after 2 days. It has gotton prety coldgoing from about55degrees down to the high 20s. My question is : Is the tender doing its job or is it shot? The bike started right up and I left the tender connected while I ran it for about a minute and the light stayed green the whole time it was running. After I shut it off the light went immediately back to red.. AmI OK or is the charger/tender shot? COMMENTS PLEASE. THANKS GUYS AND HAPPY NEW YEAR TO ALL. MACK
RE: Battery Tender Use
Had the battery on my 02 Dyna go out on me last summer, took the stator with it and was told I was luck not to loose the voltage regulator. I will be replacing batteries at least every 3 years on my 08 UC. I would also recommend not to use one of the cheapo Wal-Mart M/C batteries....I've heard horror stories about those when put in a Harley.
If you get the red light again when you think it should be green try wiggling the connector. Depending on which battery tender you have there's an issue with the male ends of the connectors. They become compressed with use & don't make good contact. Simply use a pocket knife in the slot in the side of the male connector to spread them enough to make good contact. I have three tenders & have to make this little adjustment several times a year. Takes about 15 seconds................
Thanks guys. I have the larger charging system of 45amp I believe which came stock in 03. In any case it is an 03 ULTRA with a ton of electrical stuff and the stock charging system. Will try all suggestions. In the meantime,if you think of anything else,please let me know. And since I work nfor a dealership I will definitely be going with an HD battery. With my liberal discount I cant afford to do otherwise. I am also going to have one of our techs load test it. THANKS, MACK
