MOTORCYCLE LIFT w/ 08 TOURING (CROSS MEMBER)
Ok guys, I need your help here. I'm in the market to buy a new mc lift and I noticed under my bike, an '08 Ultra Classic that there is a cross member underneath the frame that I don't remember seeing on my '03. I am concerned about being able to use a MC lift and not having interference from the cross member. Also as far as lift are concerned, I was thinking about going with the Pit Bull, but I am open to suggestions. If you have an '08 model and are using a lift, please weigh in here.
RE: MOTORCYCLE LIFT w/ 08 TOURING (CROSS MEMBER)
I also have the yellow Craftsman and it works great. I was told that the crossmember was where you shold place the rear lifting pad of the jack but mine is too wide to fit in the channel and it doesn't seem to be the proper balance point anyway.
ORIGINAL: Alsobob
ORIGINAL: tda69
That is where I put mine but have only used on my 08 a time or 2
That's exactly what I was concerned about. Either the cross-member channel being too narrow or the lift pad being too wide...whichever way you want to look at it. So I assume that you simply movedyour lifting point (rear pad) forward slightly so it's just in front of the channel, is that correct?
ORIGINAL: Alsobob
