Oil cooler question Jagg or HD
RE: Oil cooler question Jagg or HD
ORIGINAL: swipter
I am thinking for $250 shipped from Zanotti's the HD cooler may be the better choice.
Bought Harley Prem. oil cooler. Pictures on early posts. Works great. Has a chrome cover. Yes you can buy parts. Complete parts breakdown came in the box. Stock on all SE models.
Purchase at Zanotti's on line of course.
On 07 RKC
Ran Jagg on Pan. worked good mount on frame left front down tube. Phillm right just throw the cover on it for cool weather.
On 07 RKC
ORIGINAL: swipter
I read one thread where the HD kit gives issues with the voltage regulator plug in (I believe) making the oil filter difficult to put on and remove and makes it possible to break it if not careful. Is this the case?
In reply to Swipter's concern, I have the HD Premium Cooler and I found that the HD adapter moves the filter just far enough inboard that a K&N filter will not fit (too long) and the HD oil filter end cap wrench will not fit on a standard filter.Both interfere with the Crank Position Sensor.Iremove the CPS when I change out the filter. If you switch to the Jagg offset adapter, the interference goes away. -Tom
