HQ 120" dialed in
#31
RE: HQ 120" dialed in
thanks Guy,
my two main concerns are grinding the rear piston (which seems to be no prob thanks to you and Phil... and my TB had to be made different on my last motor, so im not sure if it will work on this one. prior motor was short which brought the intakes closer to each other making the TB to wide, the stock one would fit but the HPI one was too wide... hopefully it will work... allthough ive got the baby TB right now at 48mm. i did change out the injectors to the screamin eagle ones that comes in the 50mm valve body... my stump pulling grunt should be fine, curious how high up the hp pulls with the smaller TB...
you running a quiet baffle on the d&d? i got the normal one for now....
Guy, thanks for the offer, and im sure i will be consulting you as i go....
#32
#33
Yep, running the quiet baffle in the Borzilla. It is really not all that noisy, very deep sound at idle, almost a Nascar sound to it under hard acceleration.
I stuck with the 50mm TB but who knows, there are enough of us that are making this build we will learn a bit about the fueldelivery and how it impacts both torque and hp. AllanW is no help at all , he is carbed.
#34
Welcome to the site Allan!You guys are makining me so jelious.My 103 runs pretty good but I just can't emagine twisting the throttle on a 120.I do have a toy to play with if I can rake up some coins.Congrats (to all of you) on the builds.Have fun with them!
I have ideas for this puppy.
#36
ORIGINAL: Billiam92407
5K is less than I was imagining... but still not cheap.
Hmmmmmmm..... 120 build or trip to Italy, Israel, Greece and Egypt this spring....
#37
Caution: The 120" build can be hazardous to your wallet. $5k is only the engine and crank work. Add $$$ if you go to a different clutch,exhaust, throttle body, rocker boxes, fuel management, air cleaner, chrome inner primary (hey-doesn't chrome make it go faster?) oil, filters, gaskets, etc.
Don't ask me how I know...
#38
ORIGINAL: Dalton
Caution: The 120" build can be hazardous to your wallet. $5k is only the engine and crank work. Add $$$ if you go to a different exhaust, throttle body, rocker boxes, fuel management, air cleaner, chrome inner primary (hey-doesn't chrome make it go faster?) oil, filters, gaskets, etc.
#40
