loctite
12-31-2007, 03:34 PM
RE: loctite
Quote:
ORIGINAL: carpetride
...just wondering if I need to put loctite on the muffler hanger bolts
i don't and haven't had anything vibrate loose.
12-31-2007, 04:04 PM
RE: loctite
Loctite? Toss that stuff out and get some JB Weld. Will keep everything nice and tight.
12-31-2007, 04:27 PM
RE: loctite
I used a little blue.... no problems
12-31-2007, 04:36 PM
RE: loctite
test
12-31-2007, 04:58 PM
RE: loctite
I always use the blue loctite and when in doubt I also add some gorilla glue....[sm=smarty.gif]
12-31-2007, 05:03 PM
RE: loctite
Didn't use any on mine and haven't had a problem
12-31-2007, 11:11 PM
RE: loctite
Loctite on the hanger bolts is unnecessary, as they use lock washers. Never had a bolt come loose in 10 years riding FLH bikes.
01-01-2008, 06:20 AM
RE: loctite
Blue Locktite will hold most anything on the scoot, but use red when when it is safety related. You can use a high wattage soldering iron to help remove bolts locked with red locktite. Just hold the soldering iron on the bolt head for about 20 seconds and remove it as normal. ( learned this trick from a Locktite factory rep) A soldering gun won't have enough heat for very big fasteners. That's the reason for one of the big old fasioned irons. Locktite looses it's grip when heat is applied!
inswva
09-09-2011 11:15 AM
USMAMule
09-14-2010 08:48 AM
Skygoose
05-21-2008 04:41 PM
cutacroshorty
09-23-2006 05:20 PM
Retired_Ted
Exhaust System Topics
08-11-2005 03:33 AM
