Backrest questions...
Due to a misunderstanding with a 17-4 hand horse a couple of years ago (he wanted me off, I wanted to stay on, that's a long way down, and Mercer County clay is hard) I wound up with a compression fracture in the middle of my back. It starts to bother me at around the 100 mile mark. So to do any distance riding, I am thinking about getting a backrest for my Ultra. My question is, I sit all the way back on my seat (factory) With the installation of a rider backrest, would I have to sit farther up? And do they really work for relieving the strain on your back? I have never ridden with one, as I always figured they were spine snappers if you get rear ended, but looks like if I want to distance ride, which I do, I may have to install one.
RE: Backrest questions...
Get the one with remote back rest adjustment. Simple install. I have the one with the thick back rest and love it. You can bend the support bar to move it farther back for more room. I do not use mine wiht the wife on takes up room for her but she is much more comfortable to lean against anyway. Only takes a few seconds to put on or take off. I had 2 discs removed in the early 80's and the back rest help a lot. The main thing that helped me was to have my sitting position as where my arms are not too close or to far back from the bars. I had Allen at www.meancitycycles.com take care of that with my seeat.
hope this helps.
jim
hope this helps.
jim
You will feel like you are sitting a little closer to the handlebars with the backrest. I had a fractured lumbar vertebra due to a headon accident with my Road King; the backrest did not contribute to the fracture; it was a common flexion fracture that occurs allot with headon collisions - car or motorcycle. The backrest makes ridingcomfortable for me; it does take a little getting used to. In the long run it makes long-distance riding more comfortable. Email me if you have any questions.
I am also 6'-5" like Pete. I have had several touring bikes (RK's, Ultra's). Being a rider for over 30 years I have hit the pavementmy share of times and have back problems as well. I have the rider backrest on my 08 Ultra now. As stated it does sit you a little forward but it makes you sit with good posture. The relief on my back during long rides was unbelievable. I wont ever take a trip without one again. IMHO it is well worth the money.
I got the adjustable back rest this time and love it. If I'd known how much better it was I would have changed out backrest on previous bike. I'm 6'2" and once you get it and your highway pegs in the right spot I wouldn't have it any other way.
Arvid
[IMG]local://upfiles/27149/66A36E7ACFC4448CB4680EECCD2259FC.jpg[/IMG]
Arvid
Get the backrest, makes a world of difference on the long haul. I have back problems also an couldn't ride any distance without one. Moved the tour pak back to the last position, my wife fits between the tour pak and backrest fine, both of us are happy with something to lean against.
If someone hits you in the rear hard enough for the backrest to snap your back then that will be the least of your problems, they are padded pretty well.
Get the adjustable one, bend the bracket some to allow it to sit up straight as somehow they always seem to lean a little forward. Several member and I had that problem, mine was installed when I purchased the bike by the stealer.
No joke, it works great.
