I messed up Need Info or Help
Alright, I figure it fell off (no, not the crank)
I installed the HD Center Stand p/n 91573-06
The other day and I know I tightened the feet up with the jam nuts (I know it).
Obviously not well enough.
When I got home after a ride to the swap meet and bike show, one of the feet was gone.
Anyone know where I can get another foot, I dont figure anyone would have one laying around?
Or who can make another foot?
I can get 3/4"-16 bolts and jam nuts (thats the thread size).
I fly back to Canada Tuesday so I have to make this happen or wait till next month.
There is a guy in Garland, TX that does fabricating so I can use his service. I was just hoping
beyond hope someone might have a foot.
And I'm fessing up.[&o]
RE: I messed up Need Info or Help
ORIGINAL: HogBack
...Question: How did you like it before you lost the leg.. After using it, did you like it enoughto do it again?
Works as advertised.
And yes I would do i t again. And may have too
Oh one other thing about how it works.
It says in the instructions to step down on the arm and lift with the rear grab rail.
Luckily I installed those the day before.
So you may want to think about that.
Good point.
I called and the parts guy has to ask higher up to find out. Nobody is there today.
I'll find out Wed. maybe.
Also if your thinking about installing one of these yourself, you will be loosening up the entire
exhaust system from the heads on back to get it done on a FLH at least. You have to move the pipes out on the right side pretty far to get it installed on that side correctly. Just info here for the future installer.
Works good though (with both feet installed)
