SERT OR PCIII ???
SERT OR PCIII ???
Plan on buying '08 ultra classic within the week, have been wheelin' dealin with 2 h-d shops over trade-in $, service, gold card deals, etc. NOW for real question, 1 shop says SERT better for regular riding while other shop telling me save over a 100 bucks and put PCIII on it. If not doing a big bore kit use a PCIII, while other shop says sert the best but more money??? I'm putting Kerker mufflers on this bike, thats why 1 shop says put PCIII on it because with the Kerker mufflers with sert they will have to put on dyna to get it dialed in right cause its nota h-d screaming eagle part, no map made,so they will have to dyna it alot to get right??? PCIII is easier with off brand mufflers???I rode a '07 with a sert and screaming mufflers and air cleaner up grade and loved it, will a PCIII be the same???? Pulling my hair out over this, THANKS Mark
RE: SERT OR PCIII ???
You can tweak the Sert as much as you want. I would get a dyno done with any tuning device or engine upgrade. I want to know for sure it's done right. PCIII is a hang on device Sert is not. I have heard of a few PCIIIs going out but not with the Sert so far. I went with the Sert, SE A/C, Rush 2.0, Dyno on a 08UC. Happy with the results. I don't plan on anything else for now but when i do i already have the Sert which can handle any upgrade. The dyno is worth the money to me. Dropped my 08UC off in the morning and was riding it in the afternoon. You just need to do some research to see which one is going to fit best with your ideas for your bike.
captjon37:
I have on 08 RG with the same Rush 2.0, SE A/C and SERT. I have not dynoed it yet as I set it up myself using a canned map then tweeking using the "record" function. I was wondering what hp and torque numbers you got with yours properly set up. I am hoping to have mine dynoed Saturday to see how well (or poorley) I did.
Thanks,
Doug
Thanks,
Doug
Both fuel management systems can be used for any type of build. The SERT does have more "tweaking abilities" because it lets you directly into the ECU. The PCIII has been around longer than the SERT and people were usingthe PCfor builds back when there was nothing else.
I favor strongly getting a good dyno tune done. If you have tuner ask which device they like and go with that one.
