Filling tires with air
It is a PIA to check and fill the tires on the RK, there is not alot of room to get the hand in there with the air nozzle or a gauge for that matter. I like to check once a week. Wondering if there is a decent looking 90 degree nipple out there to attach to the current stem to make it easier.
RE: Filling tires with air
I use a 90 air chuck at home and went to getagauge.com and bought a gauge with i right angle(RA60X) and 11" hose for my UC. I thought about what you are looking for but did not do it because i did not want to put pressure on a angled valve. I did find a angled tire valve extension that you cans use then take off before travel. that would make travel tire filling easier.
http://www.automotive-hardware.com
ORIGINAL: masterblaster
ORIGINAL: Big Peter
You mean this ?
As far as a wheel is concerned, do you leave it attached, surely it would affect the balance of the wheel, right?
Hack
Hey kool! The website is in German!! . . . . . . I don't speak German so well.
There's got to be a US source! This is a problem I meant to look up too. There's only one gas station in my area that has a 90 deg chuck and someone ran over it a couple of weeks ago! : (
Grrr.
Grrr.
Look here:
http://www.klr650.com/90%20valve%20s...extensions.htm
or better, here:
http://www.tjtrailers.com/store/whee...cessories.html
or better, here:
