Filling tires with air
Old 12-30-2007, 12:50 PM
Stash's Avatar
Stash
Stash is offline
Default RE: Filling tires with air
Do a search on the this topic.I bought my extensions from an online RV store. Others have bought in different places....do search, not hard to find them. I leave mine in all the time. 7000 miles with no tire balance problems. Works great. No more trying to get a tire reading or adding air into that impossible place.
Old 12-30-2007, 12:53 PM
masterblaster's Avatar
masterblaster
masterblaster is offline
Thanks, I shop here for my KLR and never remember seeing this before.
Old 12-30-2007, 12:56 PM
btefft's Avatar
btefft
btefft is offline
THANK YOU! Gonna order today - for my bike (wheels and air shock).
I like the second link best.
Hack
themensh's Avatar
themensh
themensh is offline
anything you add onto your tires air valve, also increases the pressure against it while moving.
You can go to a PEP BOYS or AutoZone auto parts place and get valve caps that will indicate to you what you air pressure is (within a range).
If you are not too particular with having a black cap with a 'green' pressure range indicator.
Old 12-30-2007, 01:46 PM
Big Peter's Avatar
Big Peter
Big Peter is offline
ORIGINAL: btefft
ORIGINAL: Big Peter
ORIGINAL: masterblaster
It is a PIA to check and fill the tires on the RK, there is not alot of room to get the hand in there with the air nozzle or a gauge for that matter. I like to check once a week. Wondering if there is a decent looking 90 degree nipple out there to attach to the current stem to make it easier.
You mean this ?
I'd think that 90 degee extension would sure simplify checking the air in my air shocks. Its a PIA to remove the left bag, just to do the air shock thing. I'd just put it on and leave it. Where did you find it?
As far as a wheel is concerned, do you leave it attached, surely it would affect the balance of the wheel, right?
Hack
Hi Hack, I found it on the net in Germany
and had it shipped to me along with other goodies.
Works great on my RKC, and no problems with balance
Check out www.louis.de (site is in German) but there also
is a section in English for foreign customers.
Did some great shopping there ,and service is very good !
Greetz,
Peter
Old 12-30-2007, 02:47 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
For those running tubeless tires, you can install a right angle valve stem at your next tire change. Here's where I got mine.
http://www.americanmototire.com/inde...rget=d856.html
Old 12-30-2007, 02:58 PM
IronLegend's Avatar
IronLegend
IronLegend is offline
You're correct, it is a PITA to check the rear tire pressure. I'm middle aged and fat but I still just use my 'official genuine HD tire pressure gauge' while laying down on the ground with the valve stemat an accessible position to check it.
Old 12-30-2007, 03:20 PM
captjon37's Avatar
captjon37
captjon37 is offline
I just open my bag lid to get to the shock valve.
Old 12-30-2007, 03:27 PM
rk1121's Avatar
rk1121
rk1121 is offline
Captjon37 has posted a good site for the 90deg extensions at $3 each. I paid more for my valve caps. Thanks for the info
Old 12-30-2007, 08:53 PM
goodbirds's Avatar
goodbirds
goodbirds is offline
I bought one of those cordless air pumps with the clamp on chuck. Problem solved, and it resides in my garage next the to bike. Do my car with it too. Also serves as a jump start battery!
Quick Reply: Filling tires with air
