First putt w/ headlight modulator
RE: First putt w/ headlight modulator
Ditto, what TexasRedneck said. \\; I talked to him about mine a year or so ago before I bought one. It's a plug and play system. Just remove the screws on the headlight, unplug the light and plug the modulator in between. Run the sensor wire to the fitting on the mastercylinder and zip tie it, till you get the nerve to drill a hole to mount it in the fairing.
Since I installed mine I really noticed the cagers starting to pull out and then stop again when they see me coming. I really think its cool when they pull of the road when they see you coming:
Heres the one I bought... Great guy to talk to.
http://www.kriss.com/harleymod.php
Read their warranty carefully. \\; I know Kriss Industries sold a few years back, but the old company was infamous for declaring YOU had screwed up the product an' denying warranty. \\; I fought 'em to a standstill over it (thanks to a Dad who was an Electrical Engineer w/RCA havin' taught me a LOT about electricity), but for most folks, they'd be screwed.
I have the comagination on both bikes and have half dozen buddies that have put them in now. \\; Very easy plug and play, run the sensor through a hole in the inner fairling and cable tied to the bottom of \\;mirror stem. \\; Works great. \\; Toughest part is getting the \\;bat wing off.
I also have their brake modulator but it does require tapping into the wire going to your brake lights. \\; On my Ultra I only have \\;the upper tour pak brake lights flashing and I did the HD turn signal coversion kit. \\; It lights up like a christmas tree and the tour pak upper corners flash 4 times before \\;going solid.
