need help with tank float
1 Post
RE: need help with tank float
Hey BigMack, I replaced a fuel pump on a 2000 Road King for a buddy of mine. On the 2000 RK the fuel pump, float, and fuel filteris a complete assembly.Disconnected the hoses and moved the assembly around alot till it came out. Had to pull a little also. It´s a tight fit. Not sure about a 2003RK
Isn't it hinged or something?
There was a recent article in American Iron that did a fuel filter change.
I seem to recall it saying something about lifting the assembly up slightly and using a screwdriver to open the hinge of the float.
Don't quote me though....I don't have the mag anymore, but thought this would help you maybe.
I just changed the fuel filter on mine and in the process of trying to get the hoses off I broke the port of the fuel pump. It all was a pain in the you know what. Filter 90 bucks, Fuel pump 180 bucks. It is a tight fit coming out and gettin back in, makes u think something is not right. If you mess with the fuel pump BE CAREFUL, the hoses and factory clamps are on tight and pump can break easly. If I hadnt tried to replace the hoses I would have not broken the pump. Be careful you can damage the float easy. Its very sensitive.
