Who to do tire change?
I'm due for a new rear tire. My bike is an 05' Road King. Is there a substantial savings if I pull the rim off myself versus bringing the bike in and having the entire job done? I was thinking if I pulled the rim myself, then while I'm at it I can check the brake pads, clean the rims, etc. Checked the service manual, seems like a doable job. What do you think?
RE: Who to do tire change?
I do it myself. If I didn't, I'd definitely pull the wheel myself and have someone else mount the tire. First to save $$. Second to make sure they bike was damaged during the process. Third to make sure it went back together correctly.
As far as brake pads go, check them. Anyone who swaps pads whenhe swap tiresis probably throwing away good pads. Even with the wheel in place, it only takes about 10 minutes to put on a new set of pads.
If you're gonna do that, why not just put the new one on the rim yourself, too? It's not that hard if you've got a couple of big screwdrivers, some rimsavers, a c-clamp to break the bead and some soapy water. Everybody around me wants an arm and leg to mount a tire bought elsewhere.
ORIGINAL: xxxflhrci
My last couple of rear tires were 14,250 and 15,500 and the pads were3/4 gone both times.
yes very easy job you will need a 36mm socket 12 cresent wernch for the other side and dont forget to mark the ecrentric cam before you start you should use a toqrk wrench to reinstall.
check out the lyndall racing pads
Good luck! have a good lift and tie it down i like a floor jack under the tire also to control it after you pull the axel( don't forget antisize for the axel)
