Sacramento area dyno tuner recommendations
I'm thinking of installing a SERT on an 08 Ultra and wondered if anyone had recommendations for good tuners in the Sacramento area. My dealer is offering a package deal with Rinehart TD's, SE AC, SERT and a full 5 hour dyno tune for $1995. I'm not sure I'll go with the Rineharts, maybe SE Touring exhausts. But I think the SERT may be worth it to reduce heat issues.
Thanks.
Thanks.
RE: Sacramento area dyno tuner recommendations
Which dealer are you referring to? The one over by Arden way? Folsom Harley tuned my buddies 07 S/G with R/H T/D ect... they told him to save his money because their tunner has installed so many r/h t/d set-ups they know exactly where to put the sert and dont need to dyno them anymore. so far....I can say I have had good service from them but I personally have not had my bike tuned yet.
ORIGINAL: Hoffy
I seriously doubt they will spend 5 hours tuning a package that they are running on a special. They probably have created a MAP that they install on the bike when these parts are purchased as a package. That is not to say it will be a bad tune, just that you might not be getting as good a deal as they want you to believe.
I had my 08 UC dynoed when the SERT, SE A/C, and V&H slip-ons were put on. It took the tuner about 3 hours, he did a few runs to set up and tweek the SERT, then took it out for a test ride and finally another couple runs to make a few small adjustments. The tuner said it usually takes 5-6 runs on the dyno to get a SERT really dialed in.
