FYI M-1170 service bulletin
Go by your 07 manual. The bulletin was for the older comp nuts coming loose. Your 07 has a different bolt on it. Your IPB only lasts 25k? How does the race look when changing it out? Is the retaining ring oriented appropriately to allow oil through the feed hole? Stock auto tensioner? That could be tightening and causing the issue. Any witness marks on the inside of the primary where it would appear the basket has made contact with the rear of the inner primary?
I replaced it with Hayden?, still failed. I don;t see how the stock design would ever decrease tension. Harley probably should have gone with an aftermarket design, but didn't want to pay for it.
