What head set/communications do you use?
Old 12-25-2007, 08:49 AM
Araba Shriner's Avatar
Araba Shriner
Araba Shriner is offline
Default RE: What head set/communications do you use?
I also wear a 1/2 helmet, and didnt like the sound quality of the stock HD headsets. I purchased a real good pair of Sony, noise canceling in-the-ear headphones, and modified my MoCo system by cutting off the speakers, and installing a female jack to accomodate the Sony headphones. It blocks out a lot of wind and road noise while giving me excellent sound qualities. I can use the CB, MP3 player, XM radio, Intercom with very positive results. This type of mod may not be for all, but it serves and satifies my needs... Here are a couple images of the final product...
  #32
Old 01-07-2008, 10:11 AM
tata455's Avatar
tata455
tata455 is offline
Any links to the throat mikes? This sounds like a slick set up!! I had never thought of Bike to Bike communications until recently. I am getting into the idea. NO more yelling at each other!! Hmmm, what a concept!! [8D]
  #33
Old 01-07-2008, 11:41 AM
Bluerose
Guest
Posts: n/a
I'm usin the HD headsets which for now are just fine and were free to me.....I really only use them for the CB and intercom (don't lik the music directly in my ears)
If you want a bluetooth system you might look into Blueant I believe they have both full and 1/2 helment versions. They wrk within about 500 feet of each other and as an intercom (plus you can use your cell...though I think that is a con and not a pro[&:]). The only thing I have heard bad is that they don't last long if you try t play your music from something like a Zumo.
  #34
Old 01-07-2008, 03:17 PM
Buzzsaw's Avatar
Buzzsaw
Buzzsaw is offline
I use the MOCO headsets on 1/2 helmets..I just mounted the bracket to the helmet and then had soft material sewnto the helmet vstrap tohold the speakers in place looks and works great. This setup would work with most headsets without any drilling or mods to the helmet.
  #35
Old 08-26-2008, 10:26 AM
Merlin's Avatar
Merlin
Merlin is offline
J&M Slide-in Shorty-Style Stereo Helmet Headset w/HO Mike
I have the stock HD radio and Zumo 550.
I am using the helmet headset for CB and bluetooth calls. There is a special (low cost) interface that allows you to plug into the 2.5mm jack on the Zumo bike mount (located above the Zumo audio out 3.5mm jack) and allows you to use your helmet headset for both CB and bluetooth.
Simple, clean, inexpensive and crystal clear calls at 70mph!
striper.seeker
Audio Systems
07-26-2016 01:14 PM
SSTuner
Audio Systems
05-03-2015 04:21 PM
TenMidgets
2014-2023 Touring Models
19
05-07-2014 07:43 PM
desertwolf
09-10-2013 07:16 PM
bill1nat
10-03-2010 10:28 AM
Quick Reply: What head set/communications do you use?
