What head set/communications do you use?
RE: What head set/communications do you use?
ORIGINAL: 24guns
Well, to elaborate, I wear a half helmet and the wife wears a full face. I'd rather not modify either.
The HD headset is designed to sandwich to the edge of a full helm. Butyou can poke two tiny holes in the strap material on the side of the helm and bolt on the headset directly onto it. I use a small velcro strap to keep it from twisting.
I guess two little holes would be "modified" but I don't know how else you'd mount it to a half helm (unless you purchase a helm designed to hold the works....like the one J&M sells).
ORIGINAL: 24guns
I'm interested in any of these, but I really want a set that will not require me to drill my helmet.
Suggestions?
Suggestions?
NEVER alter the shell of your helmet; you'll just toast it.
ORIGINAL: sewerat
I am looking for a good set of throat mics to work with my radios for bike to bike system, what brand did you go with and how well can you hear them? the first set I tried you could not pick up what the other was saying. Also the ol has a smaller neck and the mic wasn't even touching her.
http://www.clearercom.com/Helmetspeaker.htm
RE: Sewerat ----- What head set/communications do you use?
Sewerat:
Here's the one I use...works well.
I notice they have a newer set that has a velcro strap
that fits around the neck... might be what your lady needs...
http://www.ixcessory.com/Merchant/me...egory_Code=XTM
I believe this company is in Singapore, so it takes a little longer for
shipping... but i have made two purchases and have had no problems..
ORIGINAL: chornbe
Uhm... never, ever, EVER drill your helmet. All the better systems come with headsets that use velcro or double sided tape to mount the stuff inside.
ORIGINAL: 24guns
Suggestions?
Suggestions?
Icould look at a 3/4 helmet I suppose, it wouldhelp with my hearing as well. I'djust use the half helmet for solo riding.
I have read a lot on this and hoped someone would have them on here by now.
http://www.myblueant.com/interphone-...helmet-kit.htm
I will buy them when I get back from Iraq but that is not until July 08.
