PCIII question re:upcoming smog laws
RE: PCIII question re:upcoming smog laws
ORIGINAL: Hoffy
If I use the fuelmoto set-up and need to change back to stock for smog check, after re-installing the stock slip-on mufflers and a/c, do I just simply remove the PCIII and the ECM goes back to normal? Or do I have to have something done to the original ECM. I understand the PCIII zip ties to the ECM and just alters the signal coming from the ECM to the injectors but does it change the ECM maps at all? Especailly since you have to "zero" the throttle?
The fact that I will have to worry about conforming to the upcoming smog laws has the largest impact on the stage one decision. I want the system that is quickest and easiest to return to stock so I can re-new my registration. Hence, slip-ons instead of full exhaust system, PCII instead of sert because with the sertI would have to plug a lap top in and know how to put the stock map backin?
