SERF'S UP
SERF'S UP
Well, I compared TFI, PCIII, SERT, V&H Fuelpak and the SERF--and decided to go with the SERF--Screamin Eagle Race Fueler. The primary reason is--my buddy who does my work (gratis)is a Harley service tech and prefers the SERF. I also decided to go with Glider's plan and use the SE stage one (parts) and use the K&N filter. Together with my SE slipons (older style) I should be fixed.
One decision I want to make before spring--if the heat situation isn't changed with the richer mixture, I'll go with either the Harley MidFrame Air Deflectors or the RJS heat shields. The RJS are much better looking--but they are pricey. I'll spend the next couple months making a decision on that. I'd like to hear from anyone using the Air Deflectors. There are several that are constantly pushing RJS--so no need for that--unless you have tried both and can compare by experience.
BTW--I ride an 08 Ultra--black (the fast one)!
Merry Christmas.
Alan
Merry Christmas.
Alan
RE: SERF'S UP
ORIGINAL: Jim Dawson
My friend installed the HD deflectors and I think they look way less obtrusive than the others. He says they work well but were a bitch to install.
RE: SERF'S UP
ORIGINAL: Badfinger
Is there no way to flash, reprogram, or adjust the original ECM to richen the mix??
Jim
Jim
You'll have to ask someone more knowledgeble than I--but all the tech guys I've discussed the 08's with have told me the same thing--I need a fuel mangagment thingy to enrich the mixture. I don't know whyit can't be tweaked to make a richer mixture. Maybe someone who knows will tell us why. I know the EPA won't like it; but if we did what they wanted, none of us would have aftermarket exhausts.
edellavedova
08-31-2009 04:32 AM
