Rinehart mounting ?
Old 12-22-2007, 09:03 AM
smokeygold's Avatar
smokeygold
smokeygold is offline
Default Rinehart mounting ?
After mounting my true duals I noticed that the mufflers are not in the same position on the little mounting slide bracket under the saddle bag. However , the mufflers appear to be even when I look at the back of the bike. What would cause the spacing on the bracket to be off by about 3/8 of an inch. Am I just being to picky?
Old 12-22-2007, 10:00 AM
gabhart's Avatar
gabhart
gabhart is offline
Default RE: Rinhart mounting ?
You are just being picky. Mine are the same. I let it go and moved on which is actually hard for me!
Old 12-22-2007, 03:53 PM
smokeygold's Avatar
smokeygold
Thanks, It just seems to me that if everthing is even they should be in the same spot on the sliding bracket.
Old 12-22-2007, 04:31 PM
framer's Avatar
framer
framer is offline
You can easily adjust that differance out with the saddlebag mounting hardware.
Old 12-22-2007, 05:23 PM
smokeygold's Avatar
smokeygold
Explain... I am not understanding what your saying.
Old 12-22-2007, 05:34 PM
TickTock's Avatar
TickTock
TickTock is offline
Can you take a picture of where you think you are off? If you measure from the rail to the end of the pipe they should be almost even. Perhaps the sliding bracket is what is off - it slides so that can not be used as an indicator.
Old 12-22-2007, 05:37 PM
robbie52's Avatar
robbie52
robbie52 is offline
The mufflers may not be on as far as the original mufflers.
Old 12-22-2007, 07:57 PM
framer's Avatar
framer
framer is offline
Sounds like your saddlebags are a wee bit out of square with each other. The mounting brackets swivel and should give you the adjustment your looking for. Hope this helps.
Old 12-23-2007, 08:29 AM
smokeygold's Avatar
smokeygold
I have the hard bags and don't see where you are refering too! Everything looks square to me!
Old 12-23-2007, 08:49 AM
TickTock's Avatar
TickTock
TickTock is offline
On the chrome rail that holds the saddlebag (where the slider attaches) , measure from the end of that to the tip exhaust.
[IMG]local://upfiles/24326/5C2E627E98BC4F65996147229AB78109.jpg[/IMG]
Quick Reply: Rinehart mounting ?
