Power outlet on Road King/customs
Old 12-20-2007 | 04:52 PM
Thunderflight's Avatar
Thunderflight
Default Power outlet on Road King/customs
I'd like to install a power outlet on my 07 RK custom, but I'm sure in the **** not going to drill a 7/8 inch hole in my side cover like the directions on the power oulet says. Anyinput?
Old 12-20-2007 | 04:55 PM
FLHT's Avatar
FLHT
Default RE: Power outlet on Road King/customs
Depends on how you plan to use it. If its for charging cell phone or the like put it in your saddle bag. I have one running in my tour pack.
Old 12-20-2007 | 05:17 PM
Thunderflight
I thought about extending the wires on the outlet and routing to the saddle bag. Will be using for charging IPOD, phone etc. Thought about using the connection to hook to a battery tender.
Old 12-20-2007 | 05:23 PM
xxxflhrci's Avatar
xxxflhrci
Use your battery tender harness.
Get a corded outlet, cut the lighter plug off of the end and put a 4 way flat on it that matches your battery tender plug. Then, just plug in the outlet and drop it in a saddlebag when you need to use it.
I did the same thing, but use my heated gear harness.
[IMG]local://upfiles/17633/1B55ADE8DEBA442A99BDA280C82CD397.jpg[/IMG]
[IMG]local://upfiles/17633/6560651FF7C74D87B6D6D069EE7F6528.jpg[/IMG]
Old 12-20-2007 | 05:36 PM
Thunderflight
Looks good, I bought the standard HD power outlet. Thanks for more ideas
Old 12-20-2007 | 07:07 PM
bikerbehaviorist's Avatar
bikerbehaviorist
I also refused to cut into my side panel instead I mounted it to the passenger peg mounting screw - see the picture. It is wired to the aux swithch on then Nacell
http://i111.photobucket.com/albums/n...werout002a.jpg
Old 12-20-2007 | 08:37 PM
Jerry L's Avatar
Jerry L
Look here for ideas:
http://www.powerletproducts.com/products.php?mid=1
Jerry
Old 12-20-2007 | 09:00 PM
rde's Avatar
rde
Ditto to the Powerlet option.
I just received my chrome Powerlet adapter for my handlebars with wiring harness today in the mail. I'm going to hardwire it to the ACC switch this winter.
The chrome will blend right in with the handlebar-looks really awesome. When not in use a spring loaded cover seals the outlet.
I plan to use it for GPS, etc. I wanted a permanent powered outlet up front on my Road King.
They have lots of options, worth a look.
Old 12-20-2007 | 09:27 PM
Hogwallop's Avatar
Hogwallop
ORIGINAL: xxxflhrci
I did the same thing with an auxillary plug. Bought an auxillary plug from Walmart and cutthe wires, then crimped ends on the wire leadsthat fit into the battery tender harnessthat hangsabove the transmission.This way you canconnect into the harness with your female auxillary. Then insert the male plug into the auxillaryfrom yourelectrical device. Iset this configuration to make a small air compressor work with a cig. plugconnector,in case of a flat.
Old 12-20-2007 | 11:22 PM
FLHT's Avatar
FLHT
ORIGINAL: Jerry L
Jerry
This is where I got my stuff, they have a great assortment of stuff to get this done the right way
Quick Reply: Power outlet on Road King/customs
