SERT Questions you should ask before install
I have a 08 ultra and have decided to go with a SERT K&N and VH TD'S. The posters on here seem to say a SERT is better if you find a good tuner. What questions shouldyou ask to try to determine if the tuner is qualified? My dealer will put either a PCIII or SERT he kinda pushes the PCIII. He aslo said that it may still pop some on decell with with either. Is that right? I'm not sure how to ask him if his tuner is any good. I had a 99 with samsons TD'S and aTFI tuner and no pop at all and ran great.
RE: SERT QUESTIONS YOU SHOULD ASK BEFORE INSTALL
I didn't think the PCIII was out yet for the 08's. Anyhow, when I bought the SERT the "N" disc wasn't out yet, it was the "L" and I used map #100 which was for 1584 engine, SE A/C and racing exhaust. That will get you close. You don't have to have the dealer do your dyno if you don't want. You can install everything and have it dyno'd anywhere. I would start asking around who is a good tuner in OH in your area. Some here may know who is a good tuner in that area.
Dawg's right. Close is close enough in 99% of the cases. As I tell my customers, unless you're turning 1/4 miles for a living, you won't see the difference. I was only using the L to N as a reference to who was "up to date". However, some bikes won't even recognize the L version. 2008's had two ECM's and the early one's caused problems. It was a pre-install issue so if your '08 was tuned on an L you're OK. Some '08's will only tune on an N.
ORIGINAL: dawg
MySERT part number is32107-01H with the CD being the "L" version. I bought my '08 Ultra on 8/30 and have used both map 100 for a Stage I upgrade and now map 106 for my recent 103" build successfully in both cases. If you buy a new SERT today, it will probably come with the "N" version CD.
