Relocating Air Shock Tubing
When mounting the bracket for a removable sissy bar the instructions say to re-route the tubing for the air shock under the fender support. I was able to get teh red grommet(?) away from the filler fitting, but the black tubing is still stuck in the fitting. I pulled but didn't want to break, this tubing seems kind of delicate. Is this suppose to slip right out?
RE: Relocating Air Shock Tubing
ORIGINAL: jsm562
This saved me from relocating and rerouting the air tubing and valve.
You can PM if you need more specifics.
Hope this helps...
