Reinharts True duals
Old 12-18-2007 | 08:55 PM
ssharley's Avatar
ssharley
1st Gear
Default Reinharts True duals
i have reinhart true duals on my 2005 electra glide, i have about 15.000 miles on them and started to hear a rattling noise coming from them at the end cap, when i pulled the end cap off i found that the baffle had worn the aluminum end cap, and that the baffles were loose inside the cap, which let them rattle, one of my friend who rides has the same problem, and he has about the same miles on his bike, has anyone had this problem? Bub, claims that it hasnt been a problem.
Old 12-18-2007 | 09:20 PM
chappy's Avatar
chappy
Default RE: Reinharts True duals
I've got about 35 to 40k on my Rineharts T/D's on my '03 Ultra. The motor has a 103" stroker plus some other performance enhancers. I do get a little tinny sound when I first start the motor, but after a warm up, the tinny sound goes away. I am running the quitest baffles though and have not tried the other baffles since first hearing the noise to see if it's the baffles or the caps.
chappy
Old 12-18-2007 | 10:22 PM
lil_gmac2's Avatar
lil_gmac2
It's a hit or miss two of my buddies had that happen to their bike but I haven't had that happen to mines.
Old 12-18-2007 | 10:38 PM
SoCal_Pappy's Avatar
SoCal_Pappy
They have replaced my TD mufflers on my '01 RKC 2 times for a loose\broken baffle (and it need it again but they say it's out of warranty)... They have also replaced the rear header pipe twice as well as the muffler end caps....
Old 12-19-2007 | 02:14 PM
lkr0's Avatar
lkr0
this is what I got after my 103 build --- at idle everything is fabulous -- hit the gas here comes the tinny sound---I'm going to a 2/1 have not decided which one--
ORIGINAL: chappy
chappy
Old 12-20-2007 | 04:49 PM
sublime_ac's Avatar
sublime_ac
Only got 5000 on mine.. Too soon to tell if they will last a long time or not..
cchenf50
06-16-2013 01:29 AM
Bobber Jake
06-24-2012 10:41 AM
t059736
06-30-2010 03:24 PM
chaswood
06-24-2008 10:43 PM
dumbjarhd
06-09-2007 02:33 AM
Quick Reply: Reinharts True duals
