Notices
Antenna question......>>>
Old 12-19-2007, 05:54 AM
big_al's Avatar
big_al
big_al is offline
Default RE: Antenna question......>>>
"That big antenna makes the bike look like some sort of full sized radio controlled toy"
That is the funniest thing I have read in here because it does.....[sm=exactly.gif]
Old 12-19-2007, 06:39 AM
pkenyon1's Avatar
pkenyon1
pkenyon1 is offline
I just bought another 08 arial, now I have two!!
Looks miles better with two and the 08 is better than the whip!
But as already said, you can get a harley kit that hides it altogether or go with a short stubby version.
Up to you!
Old 12-19-2007, 06:50 AM
VooDooChile's Avatar
VooDooChile
VooDooChile is offline
CUT YOUR STOCK ONE OFF TO THE SIZE YOU DESIRE. THE INSIDE THE FAIRING ELECTRONIC STYLE AT's ARE VERY LIMITED . HAVENT TALKED TO ONE PERSON WHO HAS HAD LUCK WITH THEM .
Old 12-19-2007, 10:02 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
"That big antenna makes the bike look like some sort of full sized radio controlled toy." That'sEXACTLY what it looks like---Perfect description.
I use a Dakota Digital knock-off--works fine in Metro Atlanta and avoids the entire antenna relocation/Tour Pak mount issue which is great since the TP is off the bike 95% of the time.
Old 12-19-2007, 10:16 AM
mhud's Avatar
mhud
mhud is offline
I bought a black rubber one about 12" in length from Auto Zone for $4.99. Seems to work as good as the stock. The material is not as flexible but it liiks great.
Old 12-19-2007, 01:23 PM
sublime_ac's Avatar
sublime_ac
sublime_ac is offline
I have the dakota digital powered antenna under the fairing and it works great.... I usually listen to an MP3 CD, but if I want FM it works fine.
Old 12-19-2007, 03:50 PM
pkenyon1's Avatar
pkenyon1
pkenyon1 is offline
I need to get a 12" black rubber one for my wife!
Old 12-19-2007, 04:59 PM
mopar7's Avatar
mopar7
mopar7 is offline
Hide it.
[IMG]local://upfiles/45252/757828325C5743C195287AECE808B266.jpg[/IMG]
Old 12-19-2007, 05:15 PM
BillyO's Avatar
BillyO
BillyO is offline
Can you say CUT, then FREE. Worked well for me.
Old 12-19-2007, 06:58 PM
Whackone's Avatar
Whackone
Whackone is offline
XM magnetic antenna for My FI by Panasonic stuck onto the rear fender behind the seat, charging/antenna mount installed in the bag and a power source from under the seat and you do not need AM, FM,or NOOA.
Quick Reply: Antenna question......>>>
