big bore build horse power not good
RE: big bore build horse power not good
ORIGINAL: Sleeps In Trees
Are they SE Performance heads? If so, installing S&S 570 cams & a new tune should get you around 100/100. You'll need to relieve the piston valve pockets & use .030" Cometic HG's.
VicW.
VicW.
ORIGINAL: tom73
Don't overlook the value of a good tune. I know someone with a similiar set-up and they are over 100 ft/lbs tq and close to 100 of HP.
Do a google search for Latus HD. They have many dyno sheets posted with different combo's. I would have expected more from what you have done.
Which SE heads?
Which SE heads?
Steve L.
ORIGINAL: gilbos440rt
Just my opinion and I might have missed something in your post but a good 2-i pipe would help I'm sure
