What is up with True Track
RE: What is up with True Track
Thanks Big Joe I appreciate the info. I will look in my service manual and check the alignment and go from there. [quote]ORIGINAL: KustomBaggers.com
ORIGINAL: Road Hawg
Big Joe, DO you have a preference on the stability controls you mentioned, also what is involved in checking the drive train alignment. I have 21k on my 07 RG and I have noticed a little morewobble in the high speed turns as i get more miles on it, I considered using the ride str8 bushings. What are your thoughts? Thanks
If you have the factory service manual for your RG the procedure is laid out for you in the manual. If you don't have one and wish to check the alignment I would recommend you get a copy. The procedure is pretty simple and affective. Harley does sell some special tools but they are not needed if you have a good set of tools and some mechanical ability. Basically it's a matter of making sure your rear tire is tracking on the same plane as your front. No two bikes ever track the same. The frames are too inconsistent. Proper alignment can some times cure the problem that the additional links are suppose to cure. The additional stabilizers can still be a good choice if improper alignment is your only issue.
Do the alignment before you try every cure all on the market.
Thanks
BigJoe
Thanks
BigJoe
I just installed this one called the Missing Link, all I can say is WOW! Made moredifference than I thought it could, I am able to use my Rivco centerstand and it looks like a clone of an STR8 very well made and installed perfect! And Price was the best thing for me!
http://cgi.ebay.com/ebaymotors/HARLE...QQcmdZViewItem
hey me again.
I just received a shipping notice from Truce-Track ( this is not atyping mistake on my part) for my order being shipped USPS with a tracking number that says its been picked up by USPS and on the way.
If that's the case, that was really quick service, AlsoI finally got through on the phone number 816-623-0697 and left a message. Ronnie called me right back and left me a message back.
So I'm pretty excited about that.
I'm thinking maybe they are having some infrastructure and/or procedural issues, ie I never received the typicalorder confirmation email, the email I sent them was returned undeliverable and sometimes their phone number gives a recording that says the number has been disconnected. These might all be problems that are not really their fault. The Truce Track Inc. is still sort of weird
Anyway I'll let you know when the part arrives. Right now I am feeling lots better
I also just noticed that paypal has their email as true-track@netscape.net when it appears their email address should be truetrack@netscape.net.
components, davidson, harley, motorcycles, phillips, ride, stabilizer, terry, track, tracktrunetscapenet, tru, trucetrack, true, trutrack, ultra, wil
