Oil change
Oil change
I am about to do my oil change in trans and motor.
I have the O rings.Now how do I go about changeing the oil and not have any oil leaking from drain plugs.
This is an honest question to you guys.It just seems that I can,t seem to
do this simple task without a bit of oil leaking.I have other bikes
and they don,t seem to have this problem
Thanks
Shortleg[Dave]
Thanks
Shortleg[Dave]
RE: Oil change
ORIGINAL: shortleg
Thanks
Shortleg[Dave]
Thanks
Shortleg[Dave]
Make sure you use new O-rings on the plugs. I like to put a little oil on them when I install them so they don't grab and tear on the way in. Go slow and make sure they seat correctly. I tore one the last time I did it because I didn't watch it closely. I don't think teflon sealer will help but I did notice that they put some on from the factory. Last thing, don't over tighten the plug.
Any one else. Am I on the right track or is there something I'm missing?
(of course, I expect a fair number of "funny" replies. I usually try to ignore them anyway)
Steve L.
RE: Oil change
You sound like an over tighten kind of guy. Use a Torque wrench (for you everything) and tighten to the specification for your make/model. If you overtighten you will strip the threads in the pan - don't ask me how I know, just trust me. I never tighten a bolt without one...
