Oil change
Old 12-09-2007, 06:42 PM
electaRICK's Avatar
electaRICK
electaRICK is offline
Default RE: Oil change
yup,, dont tkae much of a twist of the wrist to tighten them buggers,,, to much and the o-ring distorts, and oil leaks,,,,
Old 12-09-2007, 07:03 PM
Bryan TTM's Avatar
Bryan TTM
Bryan TTM is offline
JB Weld
Old 12-09-2007, 07:19 PM
rsofa's Avatar
rsofa
rsofa is offline
[sm=happybounce.gif] Ya you could have both!!!!
ORIGINAL: daddybones
All sage advice. Drink a beer....relax......enjoy the time spent alone with something that only drips, and don't nag.......
Old 12-10-2007, 12:33 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
When I did my primary, I f'ed up the o ring. Had to rush around to get a new o ring, and fluid for a trip I was taking. the little leak didn't mean much, but bugged me. And, I am on meds, LOL. So, for the second time, I applied some teflon tape to the threads, and I had no leak, and still don't.
Old 12-10-2007, 12:43 AM
captjon37's Avatar
captjon37
captjon37 is offline
I just used teflon. Figured the dealer was on to something. No leaks.
Old 12-10-2007, 02:51 AM
mike5511's Avatar
mike5511
mike5511 is offline
leaks????????????? ain't that some kind of onion????????????????
Old 12-10-2007, 06:44 AM
shortleg's Avatar
shortleg
shortleg is offline
I guess that is one place you don,t want a leak.
Have been told if you want a window you
have to bring it from home.
Shortleg[Dave]
Old 12-10-2007, 09:17 AM
ezlife's Avatar
ezlife
ezlife is offline
ORIGINAL: PapaTravis
Same here w/teflon.
New orings each time and alittle teflon. Becareful to not push the teflon up into the pan, always clean threads upon removal. Never a leak on any drain plugs.
Old 02-14-2009, 03:35 PM
regione's Avatar
regione
regione is offline
Stage II
Default speaking of drain plugs
just picked up an '08 ultra classic and want to put the HD oil temp gauge in the fairing, well read alot of posts that say the best and cheapest) way to mount the sensor is to remove the plug next to the oil drain plug (the one that requires an allen wrench to remove), put in a bushing and screw in the oil temp sender, well went to local dealership and they said under no circumstances should i remove that plug for some reason or another.. my question is does anyone know what this plug is for and will it really do any damage if removed. I figured worse case if i remove it and strip it out i have to buy a new oil pan. Opinions please.
Old 02-14-2009, 03:40 PM
teqsand's Avatar
teqsand
teqsand is offline
Big Kahuna HDF Member
Originally Posted by Bryan TTM
JB Weld
Made my day LOL
Quick Reply: Oil change
