Harley LED saddlebag lid spoilers
RE: Harley LED saddlebag lid spoilers
It's easy; the right turn signal wire is brown, the left is violet on the factory harness--at least according to my '04 HD Touring Models SM--check your model year to confirm.
I wired my saddlebagspoiler/LEDs as run/brake/turn tapping the HD module that converts the turn signals to run/brake also. You will use only one of the power wires from each LED, and the ground wire from each. The kit comes with a pigtailto plug into the accessory connector; simply cut off the pigtail to seperate the LED wiring outside the saddlebags, trim the length to suit, and splice.
If you want only turn signals, just splice the turn signal wires referenced in the first paragraph and the ground wires also.
Good luck.
Good luck.
Harleypingman
03-22-2007 02:54 AM
