LED Windshield molding kit
Hey forum has anyone installed the LED windshield molding 57335-08. I did it but I don't know If I have a defective one. When I use the turn indicators I get a bleed through to the other side, so If I use the right side turn indictor, it blinks but the left side will too. I did everything IAW the manual and still don't know what is wrong. Is this part defective?
RE: LED Windshield molding kit
Just installed one on my 2003 Ultra.......Guys at the shop were useless....they didin't even know how to wire up the new harnesses.......Figured it out on my own.......I had similar trouble.......one side worked with turn signal.....but not the other......checked my wiring again.....oposite side worked, then the other side did not........removed the small inline fuses .....found green tarnished gunk on the copper contacts inside the fuse holder......used a pencil eraser to clean contacts....all workes now......hope that may cure your problem.
