Harley HID Headlight
I found it...
Dual Bulb Halogen Headlamp Kit
The Dual Bulb Halogen Headlamp features advanced reflector optics and separate bulbs for high and low beam functions. The euro-inspired projector beam styling combines a state-of-the-art look with a CAD designed faceted reflector bowl that is optimized for crisp patterns and light cut-off. The single upper bulb functions in low beam, and both upper and lower bulb operate in high beam. The low beam setting produces a wide curb-to-curb light pattern, and the high beam adds focused light down the center of the lane without compromising width. Kit includes housing, 55 watt low beam halogen lamp, 35 watt high beam halogen lamp and all necessary mounting hardware. Does not meet ECE regulations.
ORIGINAL: mooks005
Has anyone tried the Harley HID Xenon headlight. My stock headlight on my Street Glide is not bright enough, but I am wondering if the HID makes $525 worth of difference. Would appreciate input or suggestions on alternatives.
I'm in the fortunate (?) position of being able to try a lot of new products from the MOCO, and the industry at large.
I installed the H-D HID headlight on my '05 FLHTCI as soon as they were available. I've had it on the bike for several months now.
The unit is very well designed, using quality components (Sylvania/Osram). It fits and installs perfectly, just like it was stock.
It is very bright, with a useful spread of low-beam light. The light color is intensely white. Previously, I had installed the H-D "Dual Bulb" headlight. It looks similar to the HID unit, but it is no match for beam width and brightness of the HID.
The unit's high beam is *not* HID, but a separate Halogen bulb with a projector-type lens/reflector. The unit is designed to have the HID main beam stay on when the high beam is on. Combined, there is a good throw of light down the road and to the sides when on high beam.
There are quite a "aftermarket" HID kits now appearing for m/c use. I've seen a few of them and most are pretty close to junk. I doubt they will have the reliabilty or performance of the H-D unit. There are also some Xenon-filled halogen bulbs (Silverstar, etc.) on the market that attempt to give HID performance. While better than straight halogen bulbs, they do not get close to real HID.
Expensive? Depends on your point of view, and how much you feel you need good lighting on your bike.
As someone who is actually using the product, I can say it was worth every penny.
BTW....if you can take off your outer fairing and read the excellent instructions, it's an easy self-install.
Thanks for the feedback as I have been thinking about HID myself. I love the bright WHITE look not the yellow or CHEAP blue xenon that most bulbs are.
I can say the Silverstars are a great bulb for the money if people don't wanna spend it fro true HID. I run them in my sportbike and they are a nite/day difference.
I understand the HD ,light is not worth the money. I use a 80/100 watt direct replacement halogen bulb, and it works great. Cost only $10 at autozone, mounts right in. I also use the HD 35 watt halogen driving lights. What a difference! Never had a problem of other cars "flashing" me because the excessive light. I have used this bulb on all my bikes for years. It does not run too hot even when left on high beam for extended periods of time, or draw excesive power. Make sure your light(s) are properly adjusted. You can do that yourself.
Steve
Steve
