Road King Running Bad
Old 12-30-2005 | 01:07 AM
4Scott4's Avatar
4Scott4
Default Road King Running Bad
i have a 97 fuel injected road king.. it runs great! never had a problem till today!
to start i washed it yesterday[>:]
after washing i parked it and rode it this afternoon for the first time since the wash.. it fired right up and ran fine but when i give it a quick gas it sputters... then it come thru and is fine.. like when i shift and release the clutch then twist the gas to go it spits and sputters for a second.. my brother was behind me and said when it sputtered it puffed a small amount of black smoke..
any ideas!
thamks!!!
Old 12-30-2005 | 01:38 AM
MACK's Avatar
MACK
Default RE: Road King Running Bad
SOUNDS LIKE IT MAY BE RUNNING RICH. CHECK PLUGS. REPLACE IF THEY HAVE AT LEAST 10K MILES.DRAIN GAS TANK. FILL UP WITH FRESH PREMIUM AND TRY HARLEYS FUEL ADDITIVE.OF COURSE THE BLACK SMOKE INDICATES A RICH CONDITION AND MAY HAVE TO ADJUST INJECTION SYSTEM TO CORRECTHAVE DEALER DO A CHECK.
Old 12-30-2005 | 03:20 AM
Anthony8858's Avatar
Anthony8858
This happened to me once.
Take off the right rear saddle bag.
Remove the painted cover.
Underneath that cover you'll see the EFI module. There's a big harness clip that connects to the EFI.
You have water in that clip. Open it, get a blow dryer, and let'er rip!
You'll be good to go in a few minutes.
Old 12-30-2005 | 11:26 AM
4Scott4's Avatar
4Scott4
so you are pretty sure about that huh?? i will def try it when i get home today!
Old 12-30-2005 | 12:04 PM
liam51's Avatar
liam51
Great tip, Anthony! I havent had this problem yet, however, I can see me getting all worked up, not knowing what was going on with the smoke and sputtering!
ORIGINAL: Anthony8858
Old 12-31-2005 | 01:59 AM
4Scott4's Avatar
4Scott4
i tried that today and it didnt work.... i pulled the plugs and they are really black and it smells real rich when the bike is running.. i think it might be a firing thing.. any more ideas!???!?!??!!!
Old 12-31-2005 | 02:04 AM
Grover's Avatar
Grover
Administrator Emeritus
Veteran: Marine Corp
Replace the plugs with new. They could have fouled with the way it was running while the module was wet. The module dried out in the meantime.
Old 12-31-2005 | 02:32 PM
Anthony8858
Smelling rich might be fuel that's not burning because of a fouled plug.
Change the plugs.
Old 12-31-2005 | 09:08 PM
4Scott4's Avatar
4Scott4
i changed the plugs today and i ran great! but about an hour into riding same thing again maybe even worse! i am stumped!
Old 01-01-2006 | 09:09 PM
Grover's Avatar
Grover
Can you retrieve and hard codes? Is the computer registering anything?
