WATER SOFTNERS = RUST??????
RE: WATER SOFTNERS = RUST??????
If you all want the best water to wash your rides with get a RO (reverse osmosis system). A water softener only "exchanges cations" calcium, magnesium, etc... that cause hardness (white scum) for sodium. The salt, sodium chloride, uses the sodium ion to displace the hardness ions.
Whereas a RO system actually removes these hardness ions and other anions as well to actually purify the water. A water softener does not purify it just exchanges one ion for another. Some car washes use RO systems for the final "spot free" rinse. They typically specify less than 50 ppm of TDS (total dissolved solids) for their rinse water. You can get a residential high-flow RO (5 gpm) for under $300.00. That is what I use when ever I wash any vehicle.
Probably more than you wanted to know. Sorry just cant help myself.
RE: WATER SOFTENERS = RUST??????
Hey yes the Culligan man is here to the rescue. Water softeners (ion exchange systems) will not cause your scoot to rust. The salt (brine) mixture is used to bump them nasty Magnesium and Calcium ions out of your water. In fact I would rather wash my toys with softened water than hard water. The ultimate would be using softened water and then runningitthrough a set of DI (deionization) tanks. There would be no............water spots on your bike. Just blow it dry. Of course for most this is not pratical or cost effective. You would have to swap your exhausted DI tanks $$$.
