tourpak
RE: tourpak
I figure you mean the spoiler/light kit. Put blue painter's masking tape in the area to be drilled. After marking the drill points, tap the spots with a prickpunch so the drill bit doesn't wander. Drill a small pilot hole and increase the bit size a few times until you get to the finished size hole.
Decide if you want a luggage rack before the spoiler is mounted. The TourPak looks good with the spoiler/luggage rack combination IMHO.
RE: tourpak
If you are referring to the Ultra-style wrap-around light bar, using the "search" function will give you many informative threads including this one:
https://www.hdforums.com/m_457531/tm.htm
