True Duals -Reinhart vs V & H
Old 12-03-2007, 07:30 PM
Thundercloud's Avatar
Thundercloud
Thundercloud is offline
Default RE: True Duals -Reinhart vs V & H
I have the V&H true dual head pipes with the Rinehart Eagle Beak slip on's and think they sound great.
Old 12-03-2007, 07:42 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Rinehart also makes a dual header pipe that accepts after-market slip-on mufflers; IIRC they are referred to as "Cross Dresser."
Old 12-03-2007, 08:00 PM
HSdropout's Avatar
HSdropout
HSdropout is offline
Stock head pipes, Rush slip-ons with special baffles and PCIII usb (preprogrammed)from Fuelmoto are the kind right now....Top HP and TQ
True duals look and sound good but you loose performance....check the numbers on the Fuelmoto website.............
Old 12-03-2007, 08:38 PM
rugguy51's Avatar
rugguy51
rugguy51 is offline
Steve what would every make you go back to the true duals? I thought you were a 2 into 1 man. Your bike looks great with the Fatcats.
Old 12-03-2007, 09:31 PM
btefft's Avatar
btefft
btefft is offline
Thanks for the info. After reading all these, I am leaning toward the vance and Hines. But not confirmed.
Hack
Old 12-03-2007, 11:43 PM
Guilty's Avatar
Guilty
Guilty is offline
If you aresearching for performance and a great sound, check out the V&H Pro Pipe BP. I put one these on my CVO Springer and they sound better than the V&H true duals on my RK and better than theV&H Staggered Short Shots on my wife's Low Rider. In addition, you get the advantage of better performance from the 2 into 1 exhaust. Something to consider....
Old 12-05-2007, 10:50 AM
NJVASC's Avatar
NJVASC
NJVASC is offline
Stage III
I had V&H True duals with turn down tips and just changed to Rhinehart true duals. I like the Rhineharts better. The Rhineharts have larger diameter head pipes so more output. They sound deeper to me and not as loud. Easier to hear radio at highway speeds. Picked up a little power after the change, but both are good pipes and you can't go wrong with either.
cajun1957a
06-15-2019 05:55 PM
Ray Lloyd
10-11-2013 08:38 PM
07RK/Gaub
06-24-2013 04:07 PM
blusmbl
12-09-2011 09:29 PM
deadbug
04-16-2009 09:42 AM
Quick Reply: True Duals -Reinhart vs V & H
