Rush/Fuel Moto custom baffles
Old 07-08-2008, 10:10 AM
rickoshay45's Avatar
rickoshay45
rickoshay45 is offline
Default RE: Rush/Fuel Moto custom blaffles
According to wifey there is a huge reduction of heat to the passenger footboards. She loves it.
  #72
Old 07-08-2008, 11:13 AM
vtwinbmx's Avatar
vtwinbmx
vtwinbmx is offline
i have jamie's fuelmoto setup (with pcIII, ArlenNess big sucker and jackpot/rush pipes)... is anyone getting yellowing/blueing early?&nbsp\\;\\\\\\; i'm getting that after only 2 weeks... any help?
&nbsp\\;
I have over 4500 miles with mine no problems I say give him a call. He is a great to work with I'm sure he can help.
  #73
Old 07-20-2008, 09:24 AM
2008FLHP's Avatar
2008FLHP
2008FLHP is offline
Default RE: Rush/Fuel Moto custom baffles
how much different do you think it would be with a 2" instead of the 1.75" baffle on the left?
  #74
Old 07-20-2008, 09:31 AM
rickoshay45
That would be hard to say without a dyno run. If anything, my guess is that the bottom end torque might suffer a bit. Someone may have a map for that set up that would get the most out of it.
  #75
Old 07-20-2008, 09:44 AM
speckfisher's Avatar
speckfisher
speckfisher is offline
Question? I have the Rush 2.0 on a SG and when down shifting they really gurgle alot.
&nbsp\\;\\\\\\;
They don't back fire, just pop de pop. I quess this is normal stuff?
&nbsp\\;\\\\\\;
Also I can't seem to get rid of a high pitched squeak, or chirp sound&nbsp\\;on the right side, I think it's the rubber mounting bracket for the exhaust under the saddle bag. I tried spraying silicone, helped slightly. Any suggestions?
  #76
Old 07-20-2008, 12:37 PM
iclick's Avatar
iclick
iclick is offline
ORIGINAL: speckfisher
Question? I have the Rush 2.0 on a SG and when down shifting they really gurgle alot. They don't back fire, just pop de pop. I quess this is normal stuff?
Mine doesn't pop at all, but some do. My understanding is that this can be caused by leakage around the muffler. I used anti-sieze compount to seal mine, which also will help when removing the muffler later.
Also I can't seem to get rid of a high pitched squeak, or chirp sound on the right side, I think it's the rubber mounting bracket for the exhaust under the saddle bag. I tried spraying silicone, helped slightly. Any suggestions?
Replace the rubber mount with a new one.
  #77
Old 07-20-2008, 03:30 PM
rickoshay45
I second iclick on replacing the mount. As far as the gurgling, IMHO it is normal ( I know we all are sick of hearing that phrase). I put over 30K on the stock set up and it gurgled, it was just so quiet, you could miss it. I used Permatex Copper Sealant on mine and am getting a bit of a pop, when shifting gears at lower rpms. I sent an email off to Jamie to ask his opinion. Right now the bike is out of commission. It seems to have ate some needle bearings in the tranny. The wrench caught it when doing the 35k service. I love magnetic drain plugs! At least I did not get stranded on the side of the road. And it is still under warranty!
JDSporty
2014-2023 Touring Models
02-14-2016 12:48 PM
DPete
11-19-2009 02:14 PM
dchoran
05-12-2009 10:35 PM
racinjunkie
05-11-2009 06:01 PM
mvinc01
11-14-2008 04:41 AM
Quick Reply: Rush/Fuel Moto custom baffles
