Valve Noise
Valve Noise
My 08 RKC has what sounds like valve noise to me that comes and goes. With hydraulic lifters, is it valve noise? or is something else ticking away in there? I know fuel injectors clatter, can I assume that some of the noise is coming from the injector(s)? The bike sure seems to run sweet though. It's getting better with mileage.
RE: Valve Noise
Whatever you do, do not let someone convince you that it is normal if you are not happy with the situation. If it is an issue to you, be sure you get the right people involved to figure it out. My wifes bike had a ticking and it got worse. It ended up being an issue with the cams. MOCO put in a new motor.It may be nothing but you spent the money and should be happy and satisfied.Hope you get it worked out.
