brake lever and footboard
RE: brake lever and footboard
I found that the Harley extended brake lever was not very extended and would not work with the Rineharts and probably not with other upgraded pipes. I used the ez brake and it works fine. I am now trying the soft brake extended brake lever. Looks like it will be a bit farther forward and sit a bit lower. With my big feet, I think I will really like the soft brake better. The soft brake seems to have better clearance with my pipes and I like the looks better. Hoep this helps.
