wiring cig lighter to battery
Old 11-30-2007, 09:28 PM
btefft's Avatar
btefft
btefft is offline
Default wiring cig lighter to battery
I've rigged up an after market cig lighter and plan to attach it straight to my battery. I installed a 20 A fuse in the positive wire of the rig. Ya'll reckon this will be okay? I want to have power, even when the bike's ignition is turned off off. I plan to use it for my GPS and Cell phone.
Hack
Old 11-30-2007, 09:33 PM
dawg's Avatar
dawg
dawg is offline
Received 3,230 Likes on 1,845 Posts
Default RE: wiring cig lighter to battery
Don't see a problem with it. What size wire did you use, 12awg or 14?
Old 12-03-2007, 03:14 PM
btefft's Avatar
btefft
btefft is offline
Not sure, it was the wire that came with the cig lighter. It was a deal where you had two lighters come out of one so you could power two accessories in at once. I just cut one of 'em off and rigged it up with in-line fuse and terminals so I can bolt to the battery. The wire of the fuse holder is larger, though and the fuse is 20 amp.
Hack
ORIGINAL: dawg
Old 12-03-2007, 03:26 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
20 amps sounds a bit large for a gps and cellphone. I'm guessing they would draw a fraction of that.
Old 12-03-2007, 09:49 PM
btefft's Avatar
btefft
btefft is offline
You're probably right, Weasel. I guess I need to find about the draw for my GPS and Cell and go down to a smaller fuse, huh?
Hack
ORIGINAL: BG Weasel
Old 12-04-2007, 12:59 AM
pop1's Avatar
pop1
pop1 is offline
There is an adapter at radio shack that plugs into the current lighter and has two places to plug in return looks like it works never tried it though
Old 12-04-2007, 06:01 AM
cewood's Avatar
cewood
cewood is offline
I think you would be fine. Had a similar hookup for a few years, but I was actually using it as a lighter, not for GPS.
Last weekend I purchased the 12volt accessory plug ($17) that HD sells. Plugs in to the accessory socket by the battery. Worked well after I cut it and lengthened the wires.
Old 12-04-2007, 06:16 AM
im's Avatar
im
im is offline
consider much smaller fuse rating and placement of fuse close to power source...20A sounds large.
carry spares in your bag.
Old 12-04-2007, 06:26 AM
PeteM's Avatar
PeteM
PeteM is offline
I put a 3 amp in mine, and when charging my cell hasn't blown, FWIW
Old 12-04-2007, 06:33 AM
dog155's Avatar
dog155
dog155 is offline
The fuse is to protect the wire size not what is plugged into the lighter.Where did you mount it? I currently plug my Tenders directly on the Starter wire.
Quick Reply: wiring cig lighter to battery
