Street Glide Fascia on 04 Road Glide
Old 12-01-2007, 08:12 AM
Road King Kong's Avatar
Road King Kong
Road King Kong is offline
Default RE: Street Glide Fascia on 04 Road Glide
Great mod,I am doing to the King right now.
Old 12-01-2007, 08:34 AM
IceHeritage's Avatar
IceHeritage
IceHeritage is offline
Looks Good Crash did you use the Brake-Run light or the Standard light Kit?
Old 12-01-2007, 09:14 AM
mhud's Avatar
mhud
mhud is offline
That looks great crash. I think it dresses the rear end when you fill the space between the bags. I've ordered that kit a few weeks ago for my 08 RG as well. Great Job!
Old 12-01-2007, 01:05 PM
dansflhti's Avatar
dansflhti
dansflhti is offline
I installed the red saddle bag latches last yr....they came with the red reflecters.
Old 12-01-2007, 06:30 PM
crashbike310's Avatar
crashbike310
crashbike310 is offline
Slash - The part number for the support tube cover (the part that fills the two holes where the plate used to be & saya harley Davidson in script in my pic) is 53709-04. I bought it at my local dealer for $18.50. It did not come with screws and the old hex bolts do not work. I do not have the part number for the screws. I just used some spare ones I had laying around in black.
IceHeritage- As stated in the post it is the standard light kit not the run/brake light. The part number for the run brake is 68358-07 lists $89.95
dansflhti- you got lucky or I got screwed. I ordered through Zanotti and used the part number found found in the 2008 HD parts and *** book.
mhud- you'll love the look
Old 12-01-2007, 06:38 PM
dansflhti's Avatar
dansflhti
If I could get the facia in fire red pearl....I'd be installing it now.I love that look.
But I doubt that I could get a paint match if I was to buy another color and have it painted.
Old 12-01-2007, 07:45 PM
mopar7's Avatar
mopar7
mopar7 is offline
Crashbike310, #13 you said there was a plug under your seat. Was there a plug already there?
Old 12-01-2007, 09:36 PM
crashbike310
Mopar 7 yes. If I remember it was wrapped up with the antenna. It was more towards the passenger seat and on the left side if your sitting on the bike. It also looked like I had an extra plug in where the rear turn signals plug into the mother board if you will, under the tail light cover.
My neighbor has a 07 FLHX and I just copied how his was run from the factory since I already had the plug. I have heard you can also go up under the fender and come out behind the tail light (like the rear directionals). Reminder my bike is a 04.
Hope that helps.
Old 12-01-2007, 11:17 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Mopar: I believe what Crash is describing is the bike's tour pak wiring harness that is tie wrapped with the am/fm antenna; at least that is how it is described in the HD SM for the SGtri-bar LED light connection.
Old 12-02-2007, 01:51 PM
mopar7's Avatar
mopar7
mopar7 is offline
Thanks, It is the tour pak harness.
ORIGINAL: Harleypingman
Quick Reply: Street Glide Fascia on 04 Road Glide
