"DIY MODS" and TRICKS to SAVE $$$$$$
#971
Nyokie-
Thanks man! I'm going to do this tomorrow night after work, stop at Lowe's on the way home and pick up everything. I took off my tour pak yesterday and was thinking about building a rack, and was going to make it like the MOCO one just because. This will be much easier!!
Ride Safe!
W0ACE
Ride Safe!
W0ACE
#972
Didn't like the heel toe shifter
I just made my first mod to my new FLTRU. I removed the heel shifter. I've been shifting with my toe for 50 years and couldn't get used to the heel shifter. Plus I didn't like the fact that my booted foot just fit between the heel toe levers and it kept my left foot in one position that was way ahead of my right foot which could move around on the boards. I made a spacer out of a piece of delrin about 1.3 inches long with a half inch hole through it. I slid a small O ring against the primary put the spacer on and tightened the toe shifter on the outer notch. It's way more comfortable now, plus I now have a spare shiftlever.
#973
No heel shifter
"If you know how many guns you own, you need to buy some more".
HDnutcase
#974
Windshield for a Road Glide Custom
My son and I have been ridin around and he was bitchin about the wind in his face and can't keep his hat or bandana on. He has the RG custom with the itty bitty windshield I have an Ultra. I told him to use thumb tacks or a staple gun, but you know kids they never listen. So I went to Plasticare, our local plastic supply store, bought a 1/8th inch piece of polycarbonate plastic same as lexan, for 25 bucks. I thought we'd have to heat it up to bend it but the guy at the plastic store said it'll bend, no problem. We cut it to shape, using the bottom of his and the top of mine for a pattern and made it about 1.5 inches shorter than mine 'cause he's a couple inches shorter than me. We noticed that the stock mounting is really hokey, the rubber piece on the bottom wouldn't stay on and the holes that the inside rubber plugs go into are way oversized. It's really a bad setup. HD should be ashamed to do stuff like that. Anyway we made a new windshield for his bike for $25, beats the heck out of paying HD $150+. Ours fits better than the original and holds the rubber in place. The new one we made looks and fits so good I'm tempted to make a new one for mine. The stock one is slotted and will not hold the rubber edge in the corners. Ours just has holes right where they need to be and holds everything where it belongs. He says he can hear his stereo now and his hat stays on and it looks like a touring bike should look.
I know there was another post about this but I couldn't find it again and this is definitely worth passing on.
#975
#978
And this will work just fine until (god forbid) he runs into some thing and is thrown into the shield. Shield shatters or breaks and jagged edges cut him to ribbons.
This (IMHO) is not an area to skimp on. Your money - your life - your kid. Do what you want but it's not for me.
#980
try logging out to view them. I don't know why but when I didn't have enough posts to see the pic and my session expired I was able see them so until I got my posts above 5 I think I just logged out and open the link in a new window. I know it's a pain and I don't know why unregisted users could see images but registered one couldn't until they had 5 posts.
by the way welcome to the forums. you picked a good thread to watch. very good ideas here. I suggest reading the whole thread it does take some time but you could miss some of the gems that are in here.
then again looking back a the beginning which is over 4 years old... some pics might not be around still.
cheers!!
cheers!!
