"DIY MODS" and TRICKS to SAVE $$$$$$
Old 11-10-2010, 11:36 AM
tj40kman's Avatar
tj40kman
tj40kman is offline
If you park in front of your garage door with the hi beams on, the door doesn't keep going up and down, only moves once. That tells me it only activates once (doesn't stay energized all the time).
  #682
Old 11-10-2010, 11:45 AM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
ummmmm.....I PRETTY sure you're wrong on that. One way to test your theory is to drive away with the high beams on and leave them on. Go far enough away to be out of range, then pull back up and see if the door activates as you approach. I've wired remotes up before, and IIRC, the circuit is a simple "make" one - as long as it's pressed, the circuit is "hot".
  #683
Old 11-10-2010, 03:53 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
Default pitch angle change of lower fairing side glass
The lower faring side pex glass cuases a para chute effect that hurts bike control during high cross winds such as those that you will find on bridges.
I improved this by changing the pitch angle of the lower pexi glass side pieces.
below is a pic of the original pitch angle, and the new pitch angle.
the average joe, can't tell a difference in apearence.
the bike rides totally different and is no longer effected by 40 mph cross winds.
the bike rides straight thru and the parachute effect is gone.
I replaced the original 1" #24 torx bolts with a 1 1/4, 1 1/2, and 1 3/8s #24 counter sunk screw. used a washer under the head of the screw. on the lower bolt I put a ruber faucet washer on each side of the pexi glass. on the middle screw I put a faucet washer in between the steel washer and put two faucet washers between the pexi glas and the faring. on the top screw I put a faucet washer under the steel washer, and i put 3 faucet washers between the pexi and the fairing. This results in a pitch angle change. see before and after pics
ride safe.
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-photo-1.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-photo.jpg
  #684
Old 11-10-2010, 04:20 PM
Duc's Avatar
Duc
Duc is offline
ride safe.
I can't tell a lot on the sideways pics, even turned my head :-)
Looks to me like you spaced them off mounting points from bottom to top gradually making gap bigger?
So does it make them lean back more or forward more? I am thinking back making them have less drag?
Clif
  #685
Old 11-10-2010, 07:36 PM
speakerfritz
Yes, they lean back more.
Yes, they have less drag on the top.
As you drive, if you check it, there's quite a bit of pressure being released at the gap point.
  #686
Old 11-11-2010, 12:32 PM
Duc's Avatar
Duc
Duc is offline
I like the idea behind it, going to buy parts today.
Thanks
  #687
Old 11-11-2010, 12:40 PM
speakerfritz
Default Voltage stabilizer
Motorcycle engines use a pulsating DC generator to charge the battery and operate the engine electrical components. The voltage stabilizer captures energy during each generator charge pulse, and releases it before the next charge pulse. This provide the stabilizing effect voltage stabilizers are known for.
The voltage stabilizer can be connected at various points on your bike. I have mine under my seat forward of the battery on my Harley Ultra Classic.
The Voltage stabilizer connects to the positive side of your battery or at any point on the 12V side of your electrical system.
I used a high quality, high speed, vibration tolerant electrical component using film technology.
  #688
Old 11-11-2010, 01:36 PM
CheezyRiderAZ's Avatar
CheezyRiderAZ
CheezyRiderAZ is offline
OK........
Never heard of one, tell me more......
  #689
Old 11-11-2010, 02:13 PM
pretz's Avatar
pretz
pretz is offline
Originally Posted by CheezyRiderAZ
OK........
And add a picture so we can se hat you are talking about. THanks
  #690
Old 11-11-2010, 04:02 PM
tj40kman's Avatar
tj40kman
tj40kman is offline
TR, yep you are right . I returned with the brights still on and the door opened. Not sure what effect it has with the opener energized all the time with the brights on.
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
