"DIY MODS" and TRICKS to SAVE $$$$$$
Old 09-10-2008, 10:49 PM
Old Gray Beard's Avatar
Old Gray Beard
Old Gray Beard is offline
Originally Posted by texas steve
Here is the reply from another speaker specilist and it matches what PEZ replied to me;
"When the tweeter with is crossover is wired in parallel with the existing speaker the amp will basically only see the impedance of the original speaker below the cut-off of the tweeter. Above that cut-off frequency the amp will see the tweeter in parallel with the Harley speaker. However, in all likelihood that speaker is a cone with a voice coil that has some inductance so its impedance is actually rising in this range anyway, which means paralleling the tweeter will likely not cause a real drop in the load to below 2 ohms, so all should be good."
So no problem!!
If you are using a crossover the system will see the impedence of the main speaker so there is no problem at all if you use a capacitor only to block the lower frequencies from the tweeter then you will lower the impedence one of the functions of a "crossover" is to maintain the impedence of the speaker system.
  #292
Old 09-11-2008, 07:31 PM
JUICEDSS's Avatar
JUICEDSS
JUICEDSS is offline
Default DIY Saddlebag stands
I was pretty bored tonight so I decided to make some saddlebag stands. I used 1/2" PVC and a bunch of elbows and tees. It is very sturdy and can support 1 bag at a time if need be. I will paint it in the next couple of days. It isn't collapsible like the professionally made models but I have less than $25.00 invested. Some pics:
http://i30.photobucket.com/albums/c3...agStand001.jpg
http://i30.photobucket.com/albums/c3...agStand002.jpg
http://i30.photobucket.com/albums/c3...agStand003.jpg
http://i30.photobucket.com/albums/c3...agStand004.jpg
http://i30.photobucket.com/albums/c3...agStand005.jpg
  #293
Old 09-15-2008, 05:46 PM
berettag's Avatar
berettag
berettag is offline
Hey JUICEDSS, that is really cool. Gave me a weekend project this fall. Thanks!
  #294
Old 09-18-2008, 10:01 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Uncle Scrooge is offline
Default Tire bead breaker
Here it is Harley fans, another addition to the Uncle Scrooge line of cycle accessories. It's the Scroogeomatic bead breaker, made from a few scraps of 2x and some bolts and lag screws. Just drive your car onto the platform to hold the Scroogeomatic down, put some blocks down to lift the rotor off the pavement, position your tire, and do it. This thing generates SERIOUS leverage and will break a bead in under 30 seconds. Patent pending.
  #295
Old 09-19-2008, 05:17 AM
Old Gray Beard
Will the patent applicacaton include the optional accidental death and dismemberment coverage?
  #296
Old 09-19-2008, 11:49 AM
iclick's Avatar
iclick
iclick is offline
Originally Posted by stu07hd;2551571 (from Page 5)
This is the best cheap DIY mod I have done to my 07 Ultra. It is to put an alarm siren that works with the factory alarm.
Go to Radio Shack and purchase Part #273-079 less than $6.00.
Did this yesterday and it works great. Don't know if that location is weather-proof, but it looked relatively well-protected. Can't say if the RS siren can tolerate moisture, but time will tell.
  #297
Old 09-19-2008, 11:53 AM
iclick's Avatar
iclick
iclick is offline
Good build. Another option is to buy some rubber or plastic furniture pads and install them on the bottom of the saddlebags. You can then place the bags almost anywhere without fear of scratching the paint, etc.
  #298
Old 09-20-2008, 01:02 PM
bambamblazer's Avatar
bambamblazer
bambamblazer is offline
Default Cheap Ipod mount and Tour pack light
Here is a cheap Ipod mount i made from the box it comes in. The piece i used is the "rack" the Ipod is on in the box. The light i bought at wally-world for about $6 and it just velcro's inside the tour pack
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-family-175.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-family-176.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-family-179.jpg
  #299
Old 09-21-2008, 03:37 PM
mike79's Avatar
mike79
mike79 is offline
Originally Posted by HB
This was a little tedious but it gets a lot of where did you get that bar from. I drilled 5 holes on each side of the tail light cutout and installed 10 red led's. I filled the back uo with clear silicone to help keep the led's from vibrating out. The little led holders were not real tight in the holes. Each half blinks with the corresponding blinker. Seems to work very good.
Where did you buy the LED's? Do you have a part number?
  #300
Old 09-23-2008, 01:56 AM
maltz's Avatar
maltz
maltz is offline
Stage II
Default hot motor
Originally Posted by ultrarod
I know this is old news but I am trying to decide whats best to beat the heat on my 07 ultra. I am planning on installing fuel management system just trying to decide which one. I have already installed V&H slip ons, oil cooler, stage 1 and syn 3. Helped a little but still hot so I guess I am forced to spend the $$ on a fuel maagement system. Any thoughts on which is best and should I still get aftermarket O2 repalcements are can I leave the OEM ?
I use amsoil and run a jag 10 row oil cooler and also have the oil running through my crasch bar. keep the oil down to 216 degrees on a hot day in Ca. My bike is a 2007 road glide with woods cams grear drive and ported heads.
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
