"DIY MODS" and TRICKS to SAVE $$$$$$
Old 11-14-2013, 02:38 PM
hanny's Avatar
hanny
hanny is offline
Talking
WOW!!! nice work there........something a little confusing is that youre using a 12 volt source to turn on the remote? the remote isn't 12 volt device is it? I guess it could be with 2 tiny 6 volt batteries originally. might have to give this mod a try myself
  #1412
Old 11-14-2013, 04:50 PM
jamess71's Avatar
jamess71
jamess71 is offline
I was thinking the same thing, I just had to replace the battery in my remote and it uses a 2032 battery, just 3v. I guess that 12v should work it just might have give the remote a shorter lifespan.
  #1413
Old 11-15-2013, 07:55 AM
murph's Avatar
murph
murph is offline
Not all GDO are 12v. Mine was 12v. So it was easy. You can use a 3v but you will have to use resistors to drop the bike's voltage to 3v at the GDO.
  #1414
Old 11-15-2013, 08:11 AM
jamess71's Avatar
jamess71
jamess71 is offline
Thanks Murph, I figured that must have been the case. Great write up and motivation. One less thing to remember to bring with me every morning. ;-)
  #1415
Old 11-22-2013, 01:06 PM
damquick1's Avatar
damquick1
damquick1 is offline
have you had any heat issues with the remote in the headlight housing? Just wondering before I do this.....
  #1416
Old 12-08-2013, 03:42 PM
Redlion55's Avatar
Redlion55
Redlion55 is offline
5th Gear
Default Galaxy s3 phone mount?
New to the touring world. Looking for a good mount to put phone/gps on.
Maybe bar mount or inner fairing mount??? Which would be less vibration?
  #1417
Old 12-08-2013, 04:00 PM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
ram mounts are sweet. here is how i mounted mine. I used the mirror hole on the brake. My 14 has mirrors on the fairing.
here is what i used
Amazon.com: RAM Mounts RAM 1/4in.-20 x 2 1/4in. Threaded Stud with 1in. Ball RAM-B-273U: Automotive Amazon.com: RAM Mounts RAM 1/4in.-20 x 2 1/4in. Threaded Stud with 1in. Ball RAM-B-273U: Automotive
  #1418
Old 12-08-2013, 08:34 PM
Welderman's Avatar
Welderman
Welderman is offline
My mount I believe is a version of a Ram mount made to fit the Harley switch housing. I may be wrong and it may be a Harley item, but Ram mounts are the way to go.
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-img_0025.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-img_0006.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-img_0017.jpg
  #1419
Old 12-10-2013, 05:49 PM
Gooch13's Avatar
Gooch13
Gooch13 is offline
6th Gear
Great thread. Love all the ideas. Thanks
  #1420
Old 12-19-2013, 10:18 AM
swampfox_csa's Avatar
swampfox_csa
swampfox_csa is offline
Not particularly hi-tech but have a look at the Cell Buckle. Easy on and off, inexpensive, and it can be used for different items. You can find them through several different distributors, including J&P and Motorcycle Superstore.
http://www.thecellbuckle.com/
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
